DCS-7280SE-64-F
Управляемый коммутатор Layer3, 48 портов 10 GE SFP+, 4 порта 40 GE (QSFP+), два блока питания AC, поток воздуха Front-to-Rear
Коммутатор Arista DCS-7280SE-64-F
Arista
90 497 ₽
Гарантия 3 месяца
Performance
• 7280SE-64: 48x1/10GbE and 4 x 10/40GbE
• 7280SE-68: 48x1/10GbE & 2 x 100GbE
• 7280SE-72: 48x1/10GbE & 2 x MXP
• Up to 1.44 terabits per second
• Up to 900 million packets per second
• Wire speed L2 and L3 forwarding
• Under 4 microsecond latency (64 bytes)
Data Center Optimized Design
• Ultra-deep 9GB packet buffer
• Typical power under 4W per 10GbE port
• 1+1 redundant & hot-swappable power
• N+1 redundant & hot-swappable fans
• Front-to-rear or rear-to-front cooling
• Designed for NEBS
• Tool less rails for simple installation
Virtualization and Provisioning
• VXLAN for next generation DC
• VM Tracer
• OpenFlow 1.0 and 1.3 *
• LANZ for microburst detection
• DANZ Advanced Mirroring & TAP
Aggregation for improved visibility
• Zero Touch Provisioning (ZTP)
• Advanced Event Monitoring
•sFlow (RFC3176)
• IEEE 1588 PTP
Cloud Networking Ready
• 128K-256K MAC Addresses
• 128K-256K IPv4 and IPv6 Host Routes
• 64K IPv4 Routes
Resilient Control Plane
• High Performance x86 CPU
• 4GB DRAM
• 4GB Flash
• User applications can run in a VM
Built-in Solid State Storage
• 120GB Solid State Drive
• Store logs and data captures
• Leverage linux tools with no limitations
Arista Extensible Operating System
• Single binary image
• Fine-grained truly modular network OS
• Stateful Fault Containment (SFC)
• Stateful Fault Repair (SFR)
• Full access to Linux shell and tools
• Extensible platform - bash, python, C++
Layer 2 Features
• 802.1w Rapid Spanning Tree
• 802.1s Multiple Spanning Tree Protocol
• Rapid Per Vlan Spanning Tree (RPVST+)
• 4096 VLANs
• Q-in-Q
• 802.3ad Link Aggregation/LACP
• 64 Ports / Channel
• 72 groups per system
• MLAG (Multi-Chassis Link Aggregation)
• Uses IEEE 802.3ad LACP
• 128 ports per MLAG
• 802.1Q VLANs/Trunking
• 802.1AB Link Layer Discovery Protocol
• 802.3x Flow Control
• Jumbo Frames (9216 Bytes)
• IGMP v1/v2/v3 snooping
• Storm Control
• Private VLANs *
• 802.1 AVB *
Layer 3 Features
• Static Routes
• Routing Protocols: OSPF, OSPFv3, BGP, MP-BGP, IS-IS, and RIPv2
• 128-way Equal Cost Multipath Routing (ECMP)
• VRF
• BFD
• IGMP v2/v3
• PIM-SM / PIM-SSM
• Anycast RP (RFC 4610)
• MSDP
• VRRP
• Virtual ARP (VARP)
• Policy Based Routing (PBR)
• Route Maps
Advanced Monitoring and Provisioning
• Latency Analyzer and Microburst Detection (LANZ) *
• Configurable Congestion Notification (CLI, Syslog)
• Streaming Events (GPB Encoded)
• Capture/Mirror of congested traffic *
• Advanced Mirroring
• Port Mirroring (16 sessions)
• Enhanced Remote Port Mirroring *
• SPAN/TAP M:N Aggregation *
• L2/3/4 Filtering *
• Advanced Event Management suite (AEM)
• CLI Scheduler
• Event Manager
• Event Monitor
• Linux tools
• Integrated packet capture/analysis with TCPDump
• Restore and Configure from USB
• RFC 3176 sFlow
• Integrated SSD for logging and data capture
• IEEE 1588 PTP *
Virtualization Support
• VXLAN Gateway (draft-mahlingam-dutt-dcops-vxlan-01)
• VXLAN Tunnel Endpoint
• VXLAN Bridging
• VM Tracer VMware Integration
• VMware vSphere support
• VM Auto Discovery
• VM Adaptive Segmentation
• VM Host View
Security Features
• Ingress / Egress ACLs using L2, L3, L4 fields
• ACL Logging and Counters
• Control Plane Protection (CPP)
• DHCP Relay
• MAC Security
• TACACS+
• RADIUS
• ARP trapping and rate limiting
Quality of Service (QoS) Features
• Up to 8 queues per port
• Strict priority queueing
• 802.1p based classification
• DSCP based classification and remarking *
• Egress shaping / WRR
• Policing / Shaping
• Rate limiting *
• Explicit Congestion Notification (ECN)
• Per-Priority Flow Control (PFC)
• 802.1Qaz Enhanced Transmission Selection (ETS)*
• Data Center Bridging Extensions (DCBX)*
Network Management
• CloudVision Task-Oriented Multi-Device CLI
• 100/1000 Management Port
• RS-232 Serial Console Port
• USB Port
• SNMP v1, v2, v3
• Management over IPv6
• Telnet and SSHv2
• Syslog
• AAA
• Industry Standard CLI
• Beacon LED for system identification
* Not currently supported in EOS
Extensibility
• Linux Tools
• Bash shell access and scripting
• RPM support
• Custom kernel modules
• Software Defined Networking (SDN)
• Openflow 1.0
• Openflow 1.3 *
• eAPI
• OpenStack Neutron Support
• Programmatic access to system state
• Python
• C++
• Native KVM/QEMU support
Scalability
• 96K ARP/ND Entries
• 128K-256K IPv4 Host Routes
• 64K IPv4 Unicast LPM
• 12K IPv6 Unicast LPM Routes
• 128K-256K IPv6 Unicast Host Routes
• 12K-256K Multicast Routes
• 12,000 ACL Entries per Forwarding Engine
• Up to 36,000 ACL Entries
• Virtual Output Queueing
• Distributed Scheduler
• WFQ, CIR*, ETS*, Fixed Priority
Standards Compliance
• 802.1D Bridging and Spanning Tree
• 802.1p QOS/COS
• 802.1Q VLAN Tagging
• 802.3ad Link Aggregation with LACP
• 802.3ab 1000BASE-T
• 802.3z Gigabit Ethernet
• 802.3ae 10 Gigabit Ethernet
• 802.3ba 40 Gigabit Ethernet
• 802.3ba 100 Gigabit Ethernet
• RFC 2460 Internet Protocol, Version 6 (IPv6) Specification
• RFC 2461 Neighbor Discovery for IP Version 6 (IPv6)
• RFC 2462 IPv6 Stateless Address Autoconfiguration
• RFC 2463 Internet Control Message Protocol (ICMPv6) for the
Internet Protocol Version 6 (IPv6) Specification
• IEEE 1588-2008 Precision Time Protocol
Тип коммутатора
Тип коммутатораУправляемый L3
Интерфейсы
Интерфейсы 10GBase-X SFP+48
Интерфейсы 40GBase-X4
Консольный портRS232
Management порт1000BaseT
Количество основных портов48
Тип Uplink портов40GigabitEthernet QSFP+
L2 функционал
Количество VLAN4096
Размер таблицы MAC адресов256000
Количество правил ACL36K
Протоколы L2 резервированияPVST; STP; RSTP; MSTP
Агрегирование портовLACP, MLAG
L3 функционал
Размер таблицы маршрутизации64000
Протоколы маршрутизацииOSPF; Static route; IS-IS; PIM; BGP; RIP
Питание
Arista SFP-10G-LRL
1 939 ₽
Arista SFP-10G-SR
1 566 ₽
KIT-4POST-NT
31 958 ₽
QSFP-40G-SR4-S
8 801 ₽
Arista QSFP-40G-LR4
29 963 ₽
В наличии: 3 шт
QSFP-40G-SR4
13 417 ₽
QSFP-40G-SR-BD
3 942 ₽
Коммутатор Arista DCS-7280SE-64-F c доставкой по всей России. Способ доставки вы выбираете при оформлении заказа: самовывоз со склада, курьером до адреса, в пункт выдачи заказа (ПВЗ) или до терминала транспортной компании.
