Оптический 40-гигабитный модуль с форм-фактором QSFP+ для 40G Ethernet/FCoE, соответствует стандарту 40GBASE-SR4. Предназначен для работы в многомодовом оптическом волокне (Multi mode fiber, MMF), максимальная дальность 100м, MPO-12 коннектор, поддержка функции DOM. Не поддерживает FCoE
Область применения:
- 40GBASE-SR4 Ethernet
- 4x10G breakout mode
Возможность поставки других моделей модулей QSFP+ Cisco уточняйте у менеджеров
| Product number | Description |
| QSFP-40G-SR4-S | Cisco 40GBASE-SR4 QSFP Module for MMF |
| QSFP-40G-LR4-S | Cisco 40GBASE-LR4 QSFP Module for SMF |
| QSFP-40G-SR-BD | Cisco 40GBASE-SR Bi-Directional QSFP Module for Duplex MMF |
| QSFP-40G-BD-RX | Cisco 40GBASE-SR Bi-Directional QSFP Monitor Module for Duplex MMF |
| QSFP-40G-CSR-S | Cisco 40GBASE-CSR QSFP Module for Duplex MMF |
| QSFP-40G-SR4 | Cisco 40GBASE-SR4 QSFP Module for MMF |
| FET-40G | Cisco Fabric Extender Transceiver |
| QSFP-40G-CSR4 | Cisco 40GBASE-CSR4 QSFP Module for MMF |
| QSFP-40G-LR4 | Cisco 40GBASE-LR4 QSFP Module for SMF with OTU-3 data-rate support |
| WSP-Q40GLR4L | Cisco 40GBASE-LR4L QSFP Module for SMF |
| QSFP-4X10G-LR-S | Cisco 4x10GBASE-LR QSFP Modules for SMF |
| QSFP-40G-ER4 | Cisco 40GBASE-ER4 Module for SMF with OTU-3 data-rate support |
| QSFP-4SFP10-CU0-5 | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 1/2-meter, passive |
| QSFP-4SFP10G-CU1M | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 1-meter, passive |
| QSFP-4SFP10G-CU2M | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 2-meter, passive |
| QSFP-4SFP10G-CU3M | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 3-meter, passive |
| QSFP-4SFP10G-CU4M | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 4-meter, passive |
| QSFP-4SFP10G-CU5M | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 5-meter, passive |
| QSFP-4X10G-AC7M | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 7-meter, active |
| QSFP-4X10G-AC10M | Cisco 40GBASE-CR4 QSFP to 4 10GBASE-CU SFP+ direct-attach breakout cable, 10-meter, active |
| QSFP-H40G-CU0-5M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 0.5-meter, passive |
| QSFP-H40G-CU1M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 1-meter, passive |
| QSFP-H40G-CU2M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 2-meter, passive |
| QSFP-H40G-CU3M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 3-meter, passive |
| QSFP-H40G-CU4M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 4-meter, passive |
| QSFP-H40G-CU5M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 5-meter, passive |
| QSFP-H40G-ACU7M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 7-meter, active |
| QSFP-H40G-ACU10M | Cisco 40GBASE-CR4 QSFP direct-attach copper cable, 10-meter, active |
| QSFP-4X10G-AOC1M | Cisco 40GBase-AOC QSFP to 4 SFP+ Active Optical breakout Cable, 1-meter |
| QSFP-4X10G-AOC2M | Cisco 40GBase-AOC QSFP to 4 SFP+ Active Optical breakout Cable, 2-meter |
| QSFP-4X10G-AOC3M | Cisco 40GBase-AOC QSFP to 4 SFP+ Active Optical breakout Cable, 3-meter |
| QSFP-4X10G-AOC5M | Cisco 40GBase-AOC QSFP to 4 SFP+ Active Optical breakout Cable, 5-meter |
| QSFP-4X10G-AOC7M | Cisco 40GBase-AOC QSFP to 4 SFP+ Active Optical breakout Cable, 7-meter |
| QSFP-4X10G-AOC10M | Cisco 40GBase-AOC QSFP to 4 SFP+ Active Optical breakout Cable, 10-meter |
| QSFP-H40G-AOC1M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 1-meter |
| QSFP-H40G-AOC2M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 2-meter |
| QSFP-H40G-AOC3M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 3-meter |
| QSFP-H40G-AOC5M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 5-meter |
| QSFP-H40G-AOC7M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 7-meter |
| QSFP-H40G-AOC10M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 10-meter |
| QSFP-H40G-AOC15M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 15-meter |
| QSFP-H40G-AOC20M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 20-meter |
| QSFP-H40G-AOC25M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 25-meter |
| QSFP-H40G-AOC30M | Cisco 40GBase-AOC QSFP direct-attach Active Optical Cable, 30-meter |
| CVR-QSFP-SFP10G | QSFP 40G to SFP+ 10G Adapter Module |
| Скорость модуля | 40Gbps |
| Тип оптического волокна | MMF |
| Длина волны Tx, нм | 850 |
| N7K-M206FQ-23L | 108 143 ₽ | Под заказ | ||
| WS-X6904-40G-2TXL | 522 393 ₽ | Под заказ | ||
| C6800-8P40G | 335 730 ₽ | Под заказ | ||
| C6800-8P40G-XL | 3 119 462 ₽ | Под заказ |
| N3K-C3064PQ-10GE | 110 923 ₽ | В наличии: 10+ шт | ||
| WS-C3850-24XS-S | 130 407 ₽ | В наличии: 10+ шт Транзит: 5 шт | ||
| N3K-C3064PQ-10GE_L2 | 103 713 ₽ | В наличии: 1 шт | ||
| N3K-C3064PQ-10GX | 96 675 ₽ | Под заказ | ||
| N3K-C3232C | 144 056 ₽ | Под заказ | ||
| N9K-C9316D-GX | 1 708 878 ₽ | Под заказ | ||
| N9K-C93600CD-GX | 1 230 731 ₽ | Под заказ | ||
| N9K-C9396PX | 119 914 ₽ | Под заказ | ||
| N9K-C9336C-FX2 | 527 595 ₽ | Под заказ | ||
| N9K-C9272Q | 118 509 ₽ | Под заказ |
| N6004-M12Q | 10 964 ₽ | В наличии: 3 шт |
Аналоги
| SNR-QSFP+SR4 | 5 255 ₽ | Транзит: 100+ шт |
Модуль оптический Cisco QSFP-40G-SR4-S c доставкой по всей России. Способ доставки вы выбираете при оформлении заказа: самовывоз со склада, курьером до адреса, в пункт выдачи заказа (ПВЗ) или до терминала транспортной компании.
