4G LTE modem form factor
● Embedded (included with the router)
● Upgrade FW Image Switching provisioning from (–GA SKUs) flash (FW-MC7304-LTE-AU or FWMC7304-LTE-GB)
Important 4G LTE features
● Automatic switch failover between primary and backup link
● Multichannel-interface-processor (MIP) profile configuration
● CDMA data retry
● 3G MIB with 4G LTE MIB extension and traps
● Remotely initiated data callback using voice
● Remotely initiated data callback using Short Message Service (SMS)
● Remote firmware upgrade over 4G LTE
● Virtual diagnostic monitoring
● SIM lock and unlock capabilitie
MIBs
● Enhanced 3G MIB with 4G MIB extension (4G parameters are covered with 3G MIB and 3G MIB extension)
● ENTITY MIB
● IF MIB
● 3G WWAN MIB persistence
4G LTE network management and diagnostics
● In-band and out-of-band management using Telnet (Cisco IOS Software command-line interface [CLI]) and SNMP, including MIB II and other extensions
● Industry-standard 4G LTE diagnostics and monitoring tools (Qualcomm CDMA Air Interface Tester [CAIT] and Spirent Universal Diagnostic Monitor [UDM])
Modem information
● Modem form factor: Embedded Peripheral Component Interconnect (PCI) minicard
● C88xG-4G-GA-K9 and C89xG(W)-LTE-GA-K9: Sierra Wireless MC7304 with Qualcomm MDM921
5
Wireless technologies supported (performance and throughput)
Cisco LTE 2.0 800 MHz (band 20), 900 MHz (band 8), 1800 MHz (band 3), 2100 MHz (band 1), and 2600 MHz (band 7)
Backward compatibility:
● UMTS and HSPA+: 850, 900, 1900, and 2100 MHz
● Quad-band EDGE, GPRS, and GSM: 800, 900, 1800, and 1900 MHz
● HSPA+ speed DL up to CAT20 (42.2 Mbps) and UL up to CAT6 (5.76 Mbps)
● DC-HSPA+ speed DL with CAT24 (42.2 Mbps) and UL up to CAT6 (5.76 Mbps)
| Тип устройства | Маршрутизатор |
| Поддерживаемый тип интерфейсов маршрутизатора | <Объект не найден> (234:bb7a005056b295f911ebe06e3c3f48e0) Интерфейсы 10/100/1000Base-T |
| Линейка Cisco | ISR 800 |
| ACS-890-RM-19 | 3 299 ₽ | Под заказ | ||
| SNR-RMB-890-Z | 2 039 ₽ | В наличии: 10+ шт |
