7600-ES20-10G3C
Модуль для Cisco 7600 Series, 2 порта 10G XFP (WAN), DFC3C
Модуль Cisco 7600-ES20-10G3C
Cisco
-72%
11 614
Гарантия 3 месяца
14 сентября, бесплатно
Отгрузим в ТК для доставки: 15 сентября
На данный товар возможна гарантия NAG-NBD (Next Business Day), условия и цену уточняйте у менеджера
Chassis compatibility
The 7603-S is fully supported.
Central forwarding engine compatibility
• Supervisor Engine 720-3B, 720-3BXL, Route Switch Processor 720 (RSP720) and later.
• ES20 requires dual-channel switch fabric connectivity; therefore, the 7600-ES20 is not supported with the Supervisor 32 or in slots 1 through 8 of the 7613 chassis.
Distributed Forwarding Card (DFC)
• Choice of DFC-3C or DFC-3CXL
• Line-rate distributed forwarding with services enabled, up to ~30 mpps per line card
• DFC-3C
• Designed for Carrier Ethernet-based infrastructures
• Up to 256K hardware-based forwarding entries with DFC-3C
• Up to 128K Netflow entries with DFC-3C
• DFC-3CXL
• Optimized for IP/MPLS PE mid-size and small service providers offering multiple IP services such as Layer 3 VPNs, IPv6, and triple- or quad-play services
• Up to 1 million hardware-based forwarding entries with DFC-3CXL
• Up to 256K Netflow entries with DFC-3CXL
Minimum software
Packet memory
512 Megabytes for 200 ms of combined input and output buffering at 10 Gbps
Link encapsulations
Ethernet II and IEEE 802.1q encapsulations
Hardware queues
• 16,000 queues dynamically shared between ingress and egress processing
• Hierarchical QoS (H-QoS)
MAC addresses
• Up to 80,000 MAC Addresses per ES20 Line Card
• 16 K VLAN IDs per line card (within Flexible QinQ configuration guidelines)
• Hardware-based MAC learning at wire rate
Environmental conditions
Operating temperature: 32 to 104°F (0 to 40°C)
Storage temperature: -40 to 167°F (-40 to 75°C)
Relative humidity: 10 to 90 percent, noncondensing
Operating altitude: -60 to 2000 m
MIBs
• Cisco Entity MIB (CISCO-ENTITY-MIB)
• Cisco Entity Asset MIB
• Cisco Entity Field-Replaceable Unit (FRU) Control MIB
• Cisco Entity Alarm MIB
• Interface IF MIB (RFC 2233)
• Definitions of Managed Objects for Bridges (RFC 1493)
• Evolution of Interfaces Group of MIB-II (RFC 1573)
• Simple Network Management Protocol (SNMP) MIB II (RFC 1213)
• Remote Monitoring (RMON) MIB (RFC 1757)
• Switch Monitoring (SMON) MIB
Network management
Supported with CiscoWorks, CiscoView and CiscoWorks Resource Manager Essentials (RME)
• Integrated Solution Center (ISC)
• SNMP MIB II (RFC 1213)
• IEEE 802.1ag, Connectivity Fault Management
Physical specifications
• Occupies one slot in a Cisco 7600 Series
• Up to eight (8) ES20s in a Cisco 7609 or 7609-S 9-slot chassis
• Requires Supervisor 720-3B, or 3BXL, RSP720 or later
• Dimensions (H x W x D): 1.75 x 15.375 x 16 in.
• Weight: 16 lbs.
• Mean Time Between Failure (MTBF) 80,000 hours
Power
340.2 W
Indicators
Status: green (operational); orange (faulty)
Regulatory compliance
CE Marking
Safety
• UL 60950
• CSA C22.2 No. 60950
• EN60950
• TS001
• IEC 60950
• AS/NZS3260
Electromagnetic compatibilty
• FCC Part 15 Class A
• ICES-003 Class A
• VCCI Class A
• EN55022 Class A
• CISPR22 Class A
• AS/NZS3548 Class A
• EN61000-3-2
• EN61000-3-3
• EN61000-3-1
• EN55024
• EN50082-1
• EN300 386
• ICES-003 Class A
• VCCI Class A
• EN55022 Class A
• CISPR22 Class A
• AS/NZS CISPR 22 Class A
• EN61000-3-2
• EN61000-3-3
• EN61000-6-1
• EN55024
• EN50082-1
• EN300 386
• UL 60950
• EN60950
• TS001
• IEC 60950
• AS/NZS3260
Telecommunications standards
• ITU-T G.691
• ITU-T G.707
• ITU-T G.783 Sections 9-10
• ITU-T G.784
• ITU-T G.803
• ITU-T G.813
• ITU-T G.825
• ITU-T G.826
• ITU-T G.841
• ITU-T G.957 Table 3
• ITU-T G.958FCC Part 15 Class A
• ICES-003 Class A
• VCCI Class A
• EN55022 Class A
• CISPR22 Class A
• EN61000-3-2
• EN61000-3-3
• EN61000-3-1
• EN55024
• EN50082-1
• EN300 386
• ICES-003 Class A
• VCCI Class A
• EN55022 Class A
• CISPR22 Class A
• EN61000-3-2
• EN61000-3-3
• EN61000-6-1
• EN55024
• EN50082-1
• EN300 386
Carrier Ethernet and IP/MPLS network protocols
• IPv4 unicast and multicast
• IPv6 unicast and multicast
• Multiprotocol Label Switching (MPLS) Provider Edge (PE) L2 and L3 VPNs
• Multiprotocol Label Switching Traffic Engineering (MPLS-TE)
• Multiprotocol Label Switching (MPLS) Fast Reroute (FRR)
• Diff-Serv aware MPLS TE
• GRE and IP-in-IP tunneling
• Ethernet Bridging and Ethernet Multipoint Bridging (E-MPB)
• Ethernet switching
• Ethernet over MPLS (EoMPLS)
• Switch port: access and trunk
• QinQ termination
• Selective QinQ
• Flexible QinQ
• VLAN translation
• Private VLAN
• VPLS and H-VPLS
• VLAN and Spanning Tree Protocols
• Per VLAN Spanning Tree (PVST)
• Virtual Switch Tagging (VST)
• Rapid Spanning Tree Protocol (RSTP)
• Multiple Spanning Tree (MST) Protocol: IEEE 802.1s
• VACL and VTP
QoS
• Modular QoS CLI (MQC)
• Policing granularity down to ingress, egress, physical interfaces, and VLAN
• Access control lists
• Classification, marking, policing, and queuing
• Diff-Serv Code Point (DSCP)
• Complex re-marking of Ethernet and IP/MPLS headers
Congestion avoidance
Weighted Random Early Detection (WRED) based on IP Prec, DSCP, MPLS EXP
Queuing and shaping
• Enhanced Class-based Weighted Fair Queuing (CBWFQ)
• Egress low-latency queuing (LLQ); Traffic inside LLQ may be shaped
• Two levels of queuing hierarchy
• Egress Shaping
Traffic classification and bandwidth policing
Classification based on:
• Extended ACL
• IP Precedence/IP DSCP
• MPLS Experimental Bits (EXP)
• VLAN
• Input VLAN
• Policer: Ingress single and dual-rate, three color
ACLs and security
• Up to 32,000 access list entries with no forwarding degradation
• HW counters for ACL hits
Layer 2 and Layer 3 VPNs
• Layer 2 VPNs
• EoMPLS with MAC learning
• H-VPLS (MPLS Edge or IEEE 802.1ad Edge)
• Flexible QinQ
• Layer 3 VPNs
• MPLS VPN (RFC 2547-bis)
• Inter-AS and Carrier-Supporting-Carrier
• Multicast VPN
Protection and bundling
• MPLS Fast Reroute
Спецификация.
Таблица памяти Cisco (Router Memory)
Таблица производительности (Router perfomance)
Производитель: Cisco
Модуль Cisco 7600-ES20-10G3C c доставкой по всей России. Способ доставки вы выбираете при оформлении заказа: самовывоз со склада, курьером до адреса, в пункт выдачи заказа (ПВЗ) или до терминала транспортной компании.
7600-ES20-10G3C — купить Модуль Cisco 7600-ES20-10G3C — цена, отзывы и характеристики в НАГ | 004083
