| Model | DH-IPC-HFW2200R-VF | |
| Camera | ||
| Image Sensor | 1/2.8” 2Megapixel progressive scan CMOS | |
| Effective Pixels | 1920(H)x1080(V) | |
| Scanning System | Progressive | |
| Electronic Shutter Speed | Auto/Manual, 1/3(4)~1/10000s | |
| Min. Illumination | 0. 01Lux/F1.4 (Color), 0Lux/F1.4(IR on) | |
| S/N Ratio | More than 50dB | |
| Video Output | N/A | |
| Camera Features | ||
| Max. IR LEDs Length | 30m | |
| Day/Night | Auto(ICR)/Color/B/W | |
| Backlight Compensation | BLC / HLC / DWDR | |
| White Balance | Auto/Manual | |
| Gain Control | Auto/Manual | |
| Noise Reduction | 3D | |
| Privacy Masking | Up to 4 areas | |
| Lens | ||
| Focal Length | 2.7mm~12mm | |
| Max Aperture | F1.4 | |
| Focus Control | Manual | |
| Angle of View | H: 98°~ 30° | |
| Lens Type | Manual/ Fixed Iris | |
| Mount Type | Board-in Type | |
| Video | ||
| Compression | H.264/ H.264H/ MJPEG | |
| Resolution | 1080P(1920x1080)/1.3M(1280×960)/720P(1280×720)/D1(704×576/704×480)/CIF(352×288/352×240) | |
| Frame Rate | Main Stream | 1080P/960P/720P(1 ~ 25/30fps) |
| Sub Stream | D1/CIF(1 ~ 25/30fps) | |
| Bit Rate | H.264H: 40K ~ 8192Kbps; MJPEG: 40K~16384Kbps | |
| Audio | ||
| Compression | N/A | |
| Interface | N/A | |
| Network | ||
| Ethernet | RJ-45 (10/100Base-T) | |
| Wi-Fi | N/A | |
| Protocol | IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour | |
| Compatibility | ONVIF, CGI, PSIA | |
| Max. User Access | 20 users | |
| Smart Phone | iPhone, iPad, Android, Windows Phone | |
| Auxiliary Interface | ||
| Memory Slot | N/A | |
| RS485 | N/A | |
| Alarm | N/A | |
| PIR Sensor Range | N/A | |
| General | ||
| Power Supply | DC12V/PoE (802.3af) | |
| Power Consumption | 4.5W | |
| Working Environment | -30°C~+60°C, Less than 95% RH | |
| Ingress Protection | IP66 | |
| Vandal Resistance | N/A | |
| Dimensions | 72mm×80mm×212.8mm | |
| Weight | 0.65kg | |
| Характеристики хранилища | нет |
| Общее | |
| Тип камеры | Буллет |
| Формат выходного сигнала камеры | IP |
| Размер матрицы, дюйм | 1/2.8 |
| ИК-подсветка до, м | 30 |
| Аналитика | |
| Базовая аналитика | Обнаружение движения |
| Изображение и аудио | |
| Улучшение изображения | 3D DNR / RoI / BLC / AGC |
| WDR | DWDR |
| Мин. освещенность цвет, Лк | 0.01 |
| ВидеоКодек | H.264 |
| Макс. разрешение, Мп | 2 |
| Первый поток | 25/30кс (1920x1080) |
| Второй поток | 25/30кс D1 |
| Аудио интерфейсы | без аудио |
| Оптика | |
| Режим "День/ночь" | механический ИК фильтр |
| Фокусное расстояние объектива, мм | 2.7-12 |
| Тип объектива | моторизованный |
| Диафрагма | фиксированная |
| Апертура, F | F1.4 |
| Горизонтальный угол обзора,° | 98.1-29.9 |
| Подключения и интерфейсы | |
| Локальное хранилище | нет |
| Тревожный вход/выход | нет |
| Питание | |
| Питание | 12В DC; 802.3af |
| Потребляемая мощность, Вт | 4.5 |
| Эксплуатация | |
| Пылевлагозащита | IP66 |
| Вандалостойкость | нет |
| Работа при температуре ниже -40°C | нет |
| Рабочая температура, °C | от -30 до 60 |
| Размеры, мм | 72 × 80 × 212.8 |
| ВЕС, КГ | 0.65 |
| Материал корпуса | Металл |
| Сеть | |
| Wi-Fi в камере | нет |
