DCS-7050SX-128-F
Управляемый коммутатор Layer3, 96 портов 1/10G (SFP+), 8 портов 40G (QSFP+), два блока питания AC, поток воздуха - Front-to-Back
Коммутатор Arista DCS-7050SX-128-F
Arista
Performance
  • 7050SX-128: 96 x 1/10GbE and 8x 40GbE
  • 7050SX-96: 48x 1/10GbE and 12x 40GbE
  • 7050SX-72: 48x 1/10GbE and 6x 40GbE
  • 7050SX-72Q: 48x 1/10GbE and 6x 40GbE
  • 7050SX-64: 48x 1/10GbE and 4x 40GbE
  • Up to 2.56 terabits per second
  • Up to 1.44 billion packets per second
  •  Wire speed L2 and L3 forwarding
  • Latency from 550ns
Data Center Optimized Design
  • Typical power under 2W per 10GbE port for lower cost of ownership
  • Over 94% efficient power supplies
  • 1+1 redundant & hot-swappable power
  • N+1 redundant & hot-swappable fans
  • Front-to-rear or rear-to-front cooling
  • Tool less rails for simple installation
Cloud Networking Ready
  • VXLAN and VM Tracer
  • OpenFlow, DirectFlow and eAPI
  • 288K MAC entries
  • 144K IPv4 Routes
  • 208K IPv4 Host Routes
  • 12MB Dynamic Buffer Allocation
Resilient Control Plane
  • High Performance x86 CPU
  • Up to 8GB DRAM
  • 4GB Flash
  • User applications can run in a VM
Built-in Solid State Storage
  •  Solid State Drive option
  • Store logs and data captures
  • Leverage linux tools with no limitations
Advanced Provisioning & Monitoring
  •  Zero Touch Provisioning (ZTP)
  • LANZ for microburst detection
  • DANZ Advanced Mirroring for visibility
  • sFlow
  • Self-configure and recover from USB
Arista Extensible Operating System
  • Single binary image for all products
  • Fine-grained truly modular network OS
  • Stateful Fault Containment (SFC)
  • Stateful Fault Repair (SFR)
  • Full Access to Linux shell and tools
  • Extensible platform - bash, python, C++
Тип коммутатора
Тип коммутатораУправляемый L3
Интерфейсы
Интерфейсы 10GBase-X SFP+96
Интерфейсы 40GBase-X8
Консольный портRS232
Management порт1000BaseT
Количество основных портов48
Тип Uplink портов40GigabitEthernet QSFP+
L2 функционал
Количество VLAN4096
Размер таблицы MAC адресов288000
Количество правил ACL4000
Протоколы L2 резервированияPVST; STP; RSTP; MSTP
Агрегирование портовLACP, MLAG
Количество multicast групп288000
L3 функционал
Размер таблицы маршрутизации144000
Протоколы маршрутизацииRIP; Static route; IS-IS; PIM; BGP; OSPF
Поддержка MPLSДа
Питание
