IP камера Dahua онлайн
Model |
DH-IPC-HFW4300E |
Camera |
Image Sensor |
1/3” 3Megapixel progressive scan CMOS |
Effective Pixels |
2048(H)x1536(V) |
Scanning System |
Progressive |
Electronic Shutter Speed |
Auto/Manual, 1/3(4)~1/10000s |
Min. Illumination |
0.01Lux/F1.6 (Color),0Lux/F1.6(IR on) |
S/N Ratio |
More than 50dB |
Video Output |
N/A |
Camera Features |
Max. IR LEDs Length |
30m |
Day/Night |
Auto(ICR)/Color/B/W |
Backlight Compensation |
BLC / HLC / DWDR |
White Balance |
Auto/Manual |
Gain Control |
Auto/Manual |
Noise Reduction |
3D |
Privacy Masking |
Up to 4 areas |
Lens |
Focal Length |
3.6mm (6mm,8mm optional) |
Max Aperture |
F1.8(F1.6/F1.6) |
Focus Control |
Manual |
Angle of View |
H:72.5°(44°/33.2°) |
Lens Type |
Fixed lens |
Mount Type |
Board-in Type |
Video |
Compression |
H.264/ MJPEG |
Resolution |
3M(2048×1536)/1080P(1920×1080) / 720P(1280×720) / |
Frame Rate |
Main Stream |
3M(1~20fps)/1080P/720P(1 ~ 25/30fps) |
Sub Stream |
D1/CIF(1 ~ 25/30fps) |
Bit Rate |
H.264: 32K ~ 8192Kbps |
Audio |
Compression |
N/A |
Interface |
N/A |
Network |
Ethernet |
RJ-45 (10/100Base-T) |
Wi-Fi |
N/A |
Protocol |
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour |
Compatibility |
ONVIF,PSIA,CGI |
Max. User Access |
20users |
Smart Phone |
iPhone, iPad, Android, Windows Phone |
Auxiliary Interface |
Memory Slot |
N/A |
RS485 |
N/A |
Alarm |
N/A |
PIR Sensor Range |
N/A |
General |
Power Supply |
DC12V, PoE (802.3af) |
Power Consumption |
Max 5.5W |
Working Environment |
-40°C~+60°C, Less than 95% RH |
Ingress Protection |
IP66 |
Vandal Resistance |
N/A |
Dimensions |
168.1mm×66mm×58.4mm |
Weight |
0.5kg |
