Модуль Cisco SM-SRE-710-K9
Cisco
SM-SRE-710-K9
Модуль Cisco SM-SRE-710-K9Services Ready Engine 710 (4GB RAM, 500GB HDD, 1 Core CPU 1.86 GHz)
- Комплект поставляется со штатными средствами удаленного управления Cisco (без установленных приложений)
- DRAM 1x4Gb, HDD 1х500Gb входят в комплект
Производитель: Cisco
Открыть youtube.com в новой вкладке
Product part number
SM-SRE-710-K9
SM-SRE-910-K9
Form factor
SM
SM
CPU
Intel Core2 Solo, 1.86 GHz
Intel Core2 Duo, 1.86 GHz
DRAM
4 GB
4 GB (default) or 8 GB
Compact Flash memory
2-GB internal USB flash-memory module
Hard disk
One 500-GB SATA 7200 rpm
Two 500-GB SATA
(1 TB in non-RAID mode)
Hot-swappable hard disk drive (HDD)
None
Yes
RAID support
None
RAID 0 or 1 (application dependant)
Internal network interfaces
Gigabit Ethernet connectivity to router backplane
External network interfaces
One USB connector
One RJ-45 Gigabit Ethernet connector
One USB connector
Router platforms
Cisco 2911, 2921, 2951, 3925, 3925E, 3945, and 3945E Integrated Services Routers
Cisco IOS Software (on router)
Release 15.1(4)M
Release 15.1(4)M
Embedded hardware-based cryptography acceleration
No
Yes
Power consumption (maximum)
35W
50W
Dimensions (H x W x D)
1.58 x 7.44 x 7.5 in.
(4 x 18.9 x 19.1 cm)
Shipping dimensions (H x W x D with packaging)
9.5 x 7.5 x 2.5 in.
(24.1 x 19.1 x 6.4 cm)
9.5 x 7.5 x 2.5 in.
Maximum weight
2.5 lb (1.1 kg)
2.5 lb (1.1 kg)
Operating temperature
32 to 104°F (0 to 40°C) normal
23 to 131°F (-5 to +55°C) short term
Humidity
10 to 85% operating
10 to 85% operating
Temperature
-4 to 149°F (-20 to +65°C)
Relative humidity
5 to 95%
5 to 95%
Поддерживаемый тип интерфейсов маршрутизатораИнтерфейсы 10/100/1000Base-T
Линейка CiscoМодули SM, NM, NIM, EM, EVM
