Model | DH-SD50120T-HN | ||
Camera | |||
Image Sensor | 1/3” CMOS | ||
Effective Pixels | 1280(H) x 960(V), 1.3Megapixels | ||
Scanning System | Progressive | ||
Electronic Shutter Speed | 1/3 ~ 1/30,000s | ||
Min. Illumination | Color: 0.05Lux@F1.4; B/W: 0.005Lux@F1.4 | ||
S/N Ratio | More than 55dB | ||
Camera Features | |||
Day/Night | Auto(ICR) / Color / B/W | ||
Backlight Compensation | BLC / HLC / DWDR (Digital WDR) | ||
White Balance | Auto, ATW, Indoor, Outdoor, Manual | ||
Gain Control | Auto / Manual | ||
Noise Reduction | Ultra DNR (2D/3D) | ||
Privacy Masking | Up to 24 areas | ||
Digital Zoom | 16x | ||
Lens | |||
Focal Length | 4.7mm~94mm(20x Optical zoom) | ||
Max Aperture | F1.4~ F2.6 | ||
Focus Control | Auto / Manual | ||
Angle of View | H: 54.1° ~ 3.2° | ||
Close Focus Distance | 100mm~ 1000mm | ||
PTZ | |||
Pan/Tilt Range | Pan: 0° ~ 360° endless; Tilt: 0° ~ 90°, auto flip 180° | ||
Manual Control Speed | Pan: 0.1° ~350° /s; Tilt: 0.1° ~250° /s | ||
Preset Speed | Pan: 500° /s; Tilt: 500° /s | ||
Preset | 300 | ||
PTZ Mode | 5 Pattern, 8 Tour, Auto Pan, Auto Scan | ||
Speed Setup | Human-oriented focal length/ speed adaptation | ||
Power up Action | Auto restore to previous PTZ and lens status after power failure | ||
Idle Motion | Activate Preset/ Pan/ Scan/ Tour/ Pattern if there is no command in the specified period | ||
Video | |||
Compression | H.264 / MJPEG | ||
Resolution | 1.3M(1280×960)/ 720P(1280×720) / D1(704×576/ 704×480) /CIF (352×288/352×240) |
Frame Rate | Main Stream | 1080P/ D1 (1 ~ 25/30fps), 720P(1~50/60fps) | |
Sub Stream 1 | D1/CIF(1 ~ 25/30fps) | ||
Sub Stream 2 | 720P/ D1/ CIF (1 ~ 25/30fps) | ||
Bit Rate | H.264: 448K ~ 8192Kbps | ||
Audio | |||
Compression | G.711a / G.711Mu(32kbps)/ PCM(128kbps) | ||
Interface | 1/1 channel In/Out | ||
Intelligent Function | |||
IVS | Tripwire, Intrusion, Abandoned Object Detection, Missing Object Detection | ||
Face Detection | Support | ||
Network | |||
Ethernet | RJ-45 (10/100Base-T) | ||
Protocol | IPv4/ IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, | ||
Compatibility | ONVIF PSIA CGI | ||
Max. User Access | 20 users | ||
Smart Phone | iPhone, iPad, Android, Windows Phone | ||
Auxiliary Interface | |||
Memory Slot | Micro SD, Max 64GB | ||
Alarm | 2/1 channel In/Out | ||
General | |||
Power Supply | AC24V/1.5A (±10%), POE Plus(802.3at) | ||
Power Consumption | 13W, 23W (Heater on) | 13W | |
Working Environment | -40ºC ~ 60ºC / Less than 90% RH | -20ºC ~ 60ºC / Less than 90% RH | |
Ingress Protection | IP67, IK10 | IK10 | |
Dimensions | Φ186.0(mm) x 253(mm) | Φ198(mm) x 177(mm) | |
Weight | 2.5Kg | 2.2Kg |
Каталог товаров
Екатеринбург
- Покупателям
- Услуги
- О нас
RUB
