Model |
DH-IPC-AW12W |
Camera |
Image Sensor |
1/4” Progressive scan CMOS |
Effective Pixels |
1280(H)x720(V) |
Scanning System |
Progressive |
Electronic Shutter Speed |
Auto/Manual, 1/3s~1/30000s |
Min. Illumination |
0.01lux/F1.8(color) |
S/N Ratio |
More than 50dB |
Video Output |
N/A |
Camera Features |
Max. LEDs Length |
10m |
Day/Night |
Auto(ICR) / Color / B/W |
Backlight Compensation |
BLC / HLC / DWDR |
White Balance |
Auto/Manual |
Gain Control |
Auto/Manual |
Noise Reduction |
3D |
Lens |
Focal Length |
3.6mm |
Max Aperture |
F1.8 |
Focus Control |
Manual |
Angle of View |
H:62° |
Lens Type |
Fixed Lens |
Mount Type |
Board-in Type |
PT |
Pan/ Tilt Range |
Pan: 0°~355°; Tilt: 0°~90° |
Preset Speed |
100°/s |
Preset |
25 |
Tour |
8 |
Video |
Compression |
H.264/H.264B/MJPEG |
Resolution |
720P(1280x720)/D1/CIF |
Frame Rate |
Main Stream |
720P(1~25/30fps) |
Sub Stream |
D1/CIF(1 ~ 25/30fps) |
Bit Rate |
H.264: 8Kbps~8192Kbps |
Audio |
Compression |
G.711a;G.711Mu;AAC |
Interface |
Built-in Mic & Speaker |
Network |
Ethernet |
RJ-45 (10/100Base-T) |
Wi-Fi |
Wi-Fi(IEEE802.11b/g/n) 50m(open field) |
Protocol |
IPv4/IPv6, HTTP, TCP/IP, UDP, UPnP, ICMP, IGMP, RTSP, RTP, SMTP, NTP, DHCP, DNS,FTP, QoS, |
Compatibility |
ONVIF CGI |
Max. User Access |
10 users |
Smart Phone |
iPhone, iPad, Android, Windows Phone |
Auxiliary Interface |
Memory Slot |
Micro SD, up to 64GB |
RS485 |
N/A |
Alarm |
N/A |
PIR Sensor Range |
N/A |
General |
Power Supply |
DC 5V2A |
Power Consumption |
<7.5W |
Working Environment |
-10°C~+45°C, Less than 95%RH |
Ingress Protection |
N/A |
Vandal Resistance |
N/A |
Dimensions(W×D×H) |
94mm x 94mm x 94mm |
Weight |
0.36Kg |
