Model |
DH-SD50220S-HN |
DH-SD50230S-HN |
Camera |
Image Sensor |
1/2.8” Exmor CMOS |
Effective Pixels |
1920(H) x 1080(V), 2Megapixels |
Scanning System |
Progressive |
Electronic Shutter Speed |
1/3 ~ 1/30,000s |
Min. Illumination |
Color: 0.05Lux@F1.6; B/W: 0.005Lux@F1.6 |
S/N Ratio |
More than 55dB |
Camera Features |
Day/Night |
Auto(ICR) / Color / B/W |
Backlight Compensation |
BLC / HLC / DWDR (Digital WDR) |
White Balance |
Auto, ATW, Indoor, Outdoor, Manual |
Gain Control |
Auto / Manual |
Noise Reduction |
Ultra DNR (2D/3D) |
Privacy Masking |
Up to 24 areas |
Digital Zoom |
16x |
Lens |
Focal Length |
5.5mm ~ 110.0mm |
4.3mm~129mm |
Max Aperture |
F1.6 ~ F3.5 |
F1.6~ F5.0 |
Focus Control |
Auto / Manual |
Angle of View |
H: 51° ~ 2.60° |
H: 65.1° ~ 2.34° |
Close Focus Distance |
100mm~1000mm |
PTZ |
Pan/Tilt Range |
Pan: 0° ~ 360° endless; Tilt: 0° ~ 90°, auto flip 180° |
Manual Control Speed |
Pan: 0.1° ~350° /s; Tilt: 0.1° ~250° /s |
Preset Speed |
Pan: 500° /s; Tilt: 500° /s |
Preset |
300(DH-SD) |
PTZ Mode |
5 Pattern, 8 Tour, Auto Pan, Auto Scan |
Speed Setup |
Human-oriented focal length/ speed adaptation |
Power up Action |
Auto restore to previous PTZ and lens status after power failure |
Idle Motion |
Activate Preset/ Pan/ Scan/ Tour/ Pattern if there is no command in the specified period |
Protocol |
DH-SD(Auto recognition) |
Video |
Compression |
H.264 / MJPEG |
Resolution |
1080P(1920×1080)/ 720P(1280×720) / D1(704×576/ 704×480) /CIF |
Frame Rate |
Main Stream |
1080P/ D1 (1 ~ 25/30fps), 720P(1~50/60fps) |
Sub Stream |
D1/CIF(1 ~ 25/30fps) |
Bit Rate |
H.264: 448K ~ 8192Kbps |
Audio |
Compression |
G.711a / G.711Mu(32kbps)/ PCM(128kbps) |
Interface |
1/1 channel In/Out |
Network |
Ethernet |
RJ-45 (10/100Base-T) |
Protocol |
IPv4/ IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, |
Compatibility |
ONVIF PSIA CGI |
Max. User Access |
20 users |
Smart Phone |
iPhone, iPad, Android, Windows Phone |
Auxiliary Interface |
Memory Slot |
Micro SD, Max 64GB |
Alarm |
2/1 channel In/Out |
General |
Power Supply |
AC24V/1.5A (±10%), POE plus (802.3at) |
Power Consumption |
Outdoor: 13W, 23W (Heater on) |
Working Environment |
Outdoor: -40ºC ~ 60ºC / Less than 90% RH |
Ingress Protection |
IP67(Outdoor), IK10 |
Dimensions |
Outdoor: Φ186.0(mm) x 253(mm) |
Weight |
Outdoor: 2.5kg |
Конец формы
