Model |
DH-IPC-HFW1000S-W |
Camera |
Image Sensor |
1/4” 1Megapixel progressive scan CMOS |
Effective Pixels |
1280(H)x720(V) |
Scanning System |
Progressive |
Electronic Shutter Speed |
Auto/Manual 1/3(4)~1/10000 |
Min. Illumination |
Color: 0. 01Lux/F1.8 ; 0Lux (IR on) |
S/N Ratio |
More than 50dB |
Video Output |
N/A |
Camera Features |
Max. IR LEDs Length |
30m |
Day/Night |
Auto(ICR) / Color / B/W |
Backlight Compensation |
BLC /HLC /DWDR |
White Balance |
Auto/Manual |
Gain Control |
Auto/Manual |
Noise Reduction |
3D |
Privacy Masking |
Up to 4 areas |
Lens |
Focal Length |
3.6mm (6mm optional) |
Max Aperture |
F1.8(F1.8) |
Focus Control |
Manual |
Angle of View |
H: 59°(37°) |
Lens Type |
Fixed lens |
Mount Type |
Board-in Type |
Video |
Compression |
H.264B/H.264/MJPEG |
Resolution |
720P(1280×720)/D1(704×576/704×480) /CIF(352×288/352×240) |
Frame Rate |
Main Stream |
720P(1 ~ 25/30fps) |
Sub Stream |
D1/CIF(1 ~ 25/30fps) |
Bit Rate |
H.264: 448K ~ 8192Kbps |
Audio |
Compression |
N/A |
Interface |
N/A |
Network |
Ethernet |
RJ-45 (10/100Base-T) |
Wi-Fi |
Wi-Fi(IEEE802.11b/g/n) |
Wi-Fi Range |
50m(open field) |
Protocol |
IPv4/IPv6, HTTP, HTTPS, TCP/IP, UDP, UPnP, ICMP, IGMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS |
Compatibility |
ONVIF, CGI |
Max. User Access |
20 users |
Smart Phone |
iPhone, iPad, Android, Windows Phone |
Auxiliary Interface |
Memory Slot |
N/A |
RS485 |
N/A |
Alarm |
N/A |
PIR Sensor Range |
N/A |
General |
Power Supply |
DC12V |
Power Consumption |
< 6.5W |
Working Environment |
-30°C~+50°C, Less than 95%RH |
Ingress Protection |
IP66 |
Vandal Resistance |
N/A |
Dimensions |
Φ70mm×66mm×155mm |
Weight |
0.42Kg |
Каталог товаров
Екатеринбург
- Покупателям
- Услуги
- О нас
RUB
