- Покупателям
- Услуги
- О нас
Список опций для серверов HP Proliant DL380 G7
Серверы
583970-421 | HP Proliant DL380R07 X5660 HPM (Rack2U 2xXeon6C 2.8Ghz(12Mb) /6x2GbRD/P410iwFBWC(1Gb/RAID5/ 5+0/1+0/1/0)/noHDD(8/16up) SFF/DVDRW/ICE/4xGigEth/2xRPS75 0) |
583966-421 | HP Proliant DL380 R07 X5650 HPM (Rack2U 2xXeon6C 2.66Ghz(12Mb) /6x2GbRD/P410iwFBWC(1Gb/RAID5/ 5+0/1+0/1/0)/noHDD(8/16up) SFF/DVDRW/ICE/4xGigEth/2xRPS75 0) |
583967-421 | HP Proliant DL380 R07 E5640 (Rack2U XeonQC 2.66Ghz(12Mb) /3x2GbRD/P410i(256Mb/RAID5+0/5 /1+0/1/0)/noHDD(8(16up)) SFF/noDVD/iLO2std/4xGigEth/1xR PS460) |
589150-421 | HP Proliant DL380R07 E5630 (Rack2U XeonQC 2.53Ghz(12Mb) /3x2GbRD/P410i(256Mb/RAID5+0/5 /1+0/1/0)/noHDD(8(16up)) SFF/noDVD/iLO2std/4xGigEth/1xR PS460) |
589152-421 | HP Proliant DL380 R07 E5620 (Rack2U XeonQC 2.4Ghz(12Mb) /3x2GbRD/P410i(256Mb/RAID5+0/5 /1+0/1/0)/noHDD(8(16up)) SFF/noDVD/iLO2std/4xGigEth/1xR PS460) |
583968-421 | HP Proliant DL380R07 E5506 (Rack2U XeonQC 2.13Ghz(4Mb) /2x2GbRD/P410i(ZM/RAID1+0/1/0) /noHDD(8(16up)) SFF/noDVD/iLO2std/4xGigEth/1xR PS460) |
583969-421 | HP Proliant DL380 R07 L5630 (Rack2U XeonQC 2.13Ghz(12Mb) /2x2GbUD/P410i(ZM/RAID1+0/1/0) /noHDD(8(16up)) SFF/noDVD/iLO2std/4xGigEth/1xR PS460Plat) repl 491335-421 |
Накопители на оптических дисках:
481043-B21 | HP Slim SATA DVD RW Optical Drive |
481041-B21 | HP Slim SATA DVD-ROM Optical Drive |
Процессоры:
587498-B21 | Intel® Xeon® Processor X5680 (3.33 GHz, 12MB L3 Cache, 130W,DDR3-1333, HT, Turbo 1/1/2/2/3/3) |
587493-B21 | Intel® Xeon® Processor X5670 (2.93 GHz, 12MB L3 Cache, 95W, DDR3-1333, HT, Turbo 2/2/2/2/3/3) |
587491-B21 | Intel® Xeon® Processor X5660 (2.80 GHz, 12MB L3 Cache, 95W, DDR3-1333, HT, Turbo 2/2/2/2/3/3) |
587482-B21 | Intel® Xeon® Processor X5650 (2.66 GHz, 12MB L3 Cache, 95W, DDR3-1333, HT, Turbo 2/2/2/2/3/3) |
587507-B21 | Intel® Xeon® Processor L5640 (2.26 GHz, 12MB L3 Cache, 60W, DDR3-1333, HT, Turbo 2/2/2/2/3/3) |
614547-B21 | Intel® Xeon® Processor X5677 (3.46 GHz, 12MB L3 Cache, 130W, DDR3-1333, HT, Turbo 1/1/2) |
587480-B21 | Intel® Xeon® Processor E5640 (2.66 GHz, 12MB L3 Cache, 80W, DDR3-1066, HT, Turbo 1/1/2/2) |
587478-B21 | Intel® Xeon® Processor E5630 (2.53 GHz, 12MB L3 Cache, 80W, DDR3-1066, HT, Turbo 1/1/2/2) |
587476-B21 | Intel® Xeon® Processor E5620 (2.40 GHz, 12MB L3 Cache, 80W, DDR3-1066, HT, Turbo 1/1/2/2) |
587505-B21 | Intel® Xeon® Processor L5630 (2.13 GHz, 12MB L3 Cache, 40W, DDR3-1066, HT) |
587495-B21 | Intel® Xeon® Processor E5506 (2.13 GHz, 4MB L3 Cache, 80W, DDR3-800) |
587500-B21 | Intel® Xeon® Processor E5503 (2.00 GHz, 4MB L3 Cache, 80W, DDR3-800) |
Память:
500656-B21 | HP 2GB 2Rx8 PC3-10600R-9 Kit |
500658-B21 | HP 4GB 2Rx4 PC3-10600R-9 Kit |
500660-B21 | HP 4GB 4Rx8 PC3-8500R-7 LP Kit |
593339-B21 | HP 4GB 1Rx4 PC3-10600R-9 Kit |
604504-B21 | HP 4GB 1Rx4 PC3L-10600R-9 Kit |
500662-B21 | HP 8GB 2Rx4 PC3-10600R-9 Kit |
516423-B21 | HP 8GB 2Rx4 PC3-8500R-7 Kit |
604506-B21 | HP 8GB 2Rx4 PC3L-10600R-9 Kit |
500666-B21 | 2048 MB of Advanced ECC PC2100 DDR SDRAM DIMM Memory Kit (1 x 2048 MB) |
500668-B21 | HP 1GB 1Rx8 PC3-10600E-9 Kit |
500670-B21 | HP 2GB 2Rx8 PC3-10600E-9 Kit |
500672-B21 | HP 4GB 2Rx8 PC3-10600E-9 Kit |
Жесткие диски:
507127-B21 | HP 300GB 6G SAS 10K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
492620-B21 | HP 300GB 3G SAS 10K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
512547-B21 | HP 146GB 6G SAS 15K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
504062-B21 | HP 146GB 3G SAS 15K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
507125-B21 | HP 146GB 6G SAS 10K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
418367-B21 | HP 146GB 3G SAS 10K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
512545-B21 | HP 72GB 6G SAS 15K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
418371-B21 | HP 72GB 3G SAS 15K SFF (2.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
516828-B21 | HP 600GB 6G SAS 15K LFF (3.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
516816-B21 | HP 450GB 6G SAS 15K LFF (3.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
454232-B21 | HP 450GB 3G SAS 15K LFF (3.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
516814-B21 | HP 300GB 6G SAS 15K LFF (3.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
416127-B21 | HP 300GB 3G SAS 15K LFF (3.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
384854-B21 | HP 146GB 3G SAS 15K LFF (3.5-inch) Dual Port Enterprise 3yr Warranty Hard Drive |
507610-B21 | HP 500GB 6G SAS 7.2K rpm SFF (2.5inch) Midline 1yr Warranty Hard Drive |
507616-B21 | HP 2TB 6G SAS 7.2K rpm LFF (3.5-inch) Dual Port Midline 1yr Warranty Hard Drive |
507614-B21 | HP 1TB 6G SAS 7.2K rpm LFF (3.5-inch) Dual Port Midline 1yr Warranty Hard Drive |
461137-B21 | HP 1TB 3G SAS 7.2K rpm LFF(3.5-inch) Dual Port Midline 1yr Warranty Hard Drive |
507750-B21 | HP 500GB 3G SATA 7.2K rpm SFF (2.5-inch) Midline 1yr Warranty Hard Drive |
530888-B21 | HP 160GB 3G SATA 7.2K rpm SFF (2.5-inch) Midline 1yr Warranty Hard Drive |
507632-B21 | HP 2TB 3G SATA 7.2K rpm LFF (3.5-inch) Midline 1yr Warranty Hard Drive |
460355-B21 | HP 250GB 3G SATA 5.4K rpm SFF (2.5-inch) Entry 1yr Warranty Hard Drive |
571230-B21 | HP 250GB 3G SATA 7.2K rpm LFF (3.5-inch) Entry 1yr Warranty Hard Drive |
458945-B21 | HP 160GB 3G SATA 7.2K rpm LFF (3.5-inch) Entry 1yr Warranty Hard Drive |
572071-B21 | HP 60GB 3G SATA 2.5in MDL 1y Wty SSD |
572073-B21 | HP 120GB 3G SATA 2.5in MDL 1y Wty SSD |
570761-B21 | HP 60GB 3G SATA 3.5in MDL 1y Wty SSD |
570763-B21 | HP 120GB 3G SATA 3.5in MDL 1y Wty SSD |
Контроллеры и опции:
462828-B21 | HP Smart Array P212/Zero Memory Controller |
462834-B21 | HP Smart Array P212/256 MB Controller |
462830-B21 | HP Smart Array P411/256MB Controller |
462832-B21 | HP Smart Array P411/512MB with BBWC Controller |
578229-B21 | HP Smart Array P411/512MB Flash Backed Write Cache |
572531-B21 | HP Smart Array P411/1G Flash Backed Write Cache |
487204-B21 | HP Smart Array P812/1G Flash Backed Cache Controller |
462968-B21 | 256 MB Cache Module |
462967-B21 | 512MB BBWC |
534916-B21 | 512MB Flash Backed Write Cache |
534562-B21 | 1G Flash Backed Write Cache |
462969-B21 | Battery Kit upgrade |
496013-B21 | Mini-SAS to Mini-SAS, 25.50" & 28.00" |
516471-B21 | HP Smart Array Advanced Pack No Media 1-Server license including 1yr 24x7 |
488765-B21 | HP SC08Ge Host Bus Adapter |
412911-B21 | HP SC11Xe Host Bus Adapter |
Сервис и поддержка:
U4544E | 4-Hour On-site Service, 5-Day x 13-Hour Coverage, 3 Years, Electronic |
U4545E | 4-Hour On-site Service, 7-Day x 24-Hour Coverage, 3 Years, Electronic |
U4546E | 6-Hour Call to Repair, On-site Service, 7-Day x 24-Hour Coverage, 3 Years, Electronic |
U4554E | Hardware Installation, Electronic |
U4555E | Installation & Start-Up of a ProLiant server and Microsoft or Linux O/S per the Customer Description and/or Data Sheet |
U5683E | Installation and Startup for Essentials Rapid Deployment Pack, Electronic |
U4556E | Onsite HW support, 8am-9pm, M-F, 4hr response and Microsoft O/S SW Tech support offsite, onsite at HP's discretion, 8am-9pm, M-F 2hr response time excl. HP holidays, Electronic |
U4557E | Onsite HW support 24x7, 4hr response and Microsoft O/S SW Tech support offsite, onsite at HP's discretion, 24x7 2hr response time incl. HP holidays, Electronic |
U6312E | Onsite HW support 24x7, 4hr response and SuSE Linux SW Tech support offsite, onsite at HP's discretion, 24x7 2hr response time incl. HP holidays, Electronic |
