IP камера Dahua DH-IPC-AW12WP для дома и офиса 1Мп, объектив 3.6мм,wi-fi, поворотная, с микрофоном и динамиком
Dahua
EndOfSale
Артикул:DH-IPC-AW12WP
Код товара: 18279
Dahua
Снят с продажи
Model
DH-IPC-AW12W
Camera
Image Sensor
1/4” Progressive scan CMOS
Effective Pixels
1280(H)x720(V)
Scanning System
Progressive
Electronic Shutter Speed
Auto/Manual, 1/3s~1/30000s
Min. Illumination
0.01lux/F1.8color
S/N Ratio
More than 50dB
Video Output
N/A
Camera Features
Max. LEDs Length
10m
Day/Night
Auto(ICR) / Color / B/W
Backlight Compensation
BLC / HLC / DWDR
White Balance
Auto/Manual
Gain Control
Auto/Manual
Noise Reduction
3D
Lens
Focal Length
3.6mm
Max Aperture
F1.8
Focus Control
Manual
Angle of View
H:62°
Lens Type
Fixed Lens
Mount Type
Board-in Type
PT
Pan/ Tilt Range
Pan: 0°~355°; Tilt: 0°~90°
Preset Speed
100°/s
Preset
25
Tour
8
Video
Compression
H.264/H.264B/MJPEG
Resolution
720P(1280x720)/D1/CIF
Frame Rate
Main Stream
720P(1~25/30fps)
Sub Stream
D1/CIF(1 ~ 25/30fps)
Bit Rate
H.264: 8Kbps8192Kbps
Audio
Compression
G.711a;G.711Mu;AAC
Interface
Built-in Mic & Speaker
Network
Ethernet
RJ-45 (10/100Base-T)
Wi-Fi
Wi-Fi(IEEE802.11b/g/n) 50m(open field)
Protocol
IPv4/IPv6, HTTP, TCP/IP, UDP, UPnP, ICMP, IGMP, RTSP, RTP, SMTP, NTP, DHCP, DNS,FTP, QoS,
Compatibility
ONVIF CGI
Max. User Access
10 users
Smart Phone
iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot
Micro SD, up to 64GB
RS485
N/A
Alarm
N/A
PIR Sensor Range
N/A
General
Power Supply
DC 5V2A
Power Consumption
<7.5W
Working Environment
-10°C~+45°C, Less than 95%RH
Ingress Protection
N/A
Vandal Resistance
N/A
Dimensions(W×D×H)
94mm x 94mm x 94mm
Weight
0.36Kg
