IP камера Dahua DH-IPC-HDBW1200EP-W купольная мини 2.0Мп, объектив 3.6мм,wi-fi, вандалозащищенная
Dahua
EndOfSale
Артикул:DH-IPC-HDBW1200EP-W
Код товара: 16639
Dahua
Миникупольная IP камера 2Мп, Wi-Fi, без PoE, Вандалозащищенная.
Снят с продажи
Model
DH-IPC-HDBW1200E-W
Camera
Image Sensor
1/3” 3Megapixel CMOS
Effective Pixels
2048 (H)x1536(V)
Scanning System
Progressive
Electronic Shutter Speed
Auto/Manual, 1/3(4)~1/10000s
Min. Illumination
0. 1Lux/F1.8(Color),0Lux/F1.8 (IR on)
S/N Ratio
More than 50dB
Video Output
N/A
Camera Features
Max. IR LEDs Length
30m
Day/Night
Auto(ICR)/Color/B/W
Backlight Compensation
BLC / HLC / DWDR
White Balance
Auto/Manual
Gain Control
Auto/Manual
Noise Reduction
2D
Privacy Masking
Up to 4 areas
Lens
Focal Length
3.6mm (2.8mm, 6mm optional)
Max Aperture
F1.8(F2.0,F1.6)
Focus Control
Manual
Angle of View
H:71.9°(90°/45°)
Lens Type
Fixed lens
Mount Type
Board-in Type
Video
Compression
H.264/ MJPEG
Resolution
1080P(1920×1080) / 720P(1280×720) / D1(704×576/704×480) /
CIF(352×288/352×240)
Frame Rate
Main Stream
1080P/720P(1 ~ 25/30fps)
Sub Stream
D1/CIF(1 ~ 25/30fps)
Bit Rate
H.264: 16K ~ 8192Kbps
Audio
Compression
N/A
Interface
N/A
Network
Ethernet
RJ-45 (10/100Base-T)
Wi-Fi
Wi-Fi(802.11b/g/n)
Protocol
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour
Compatibility
ONVIF,CGI
Max. User Access
20 users
Smart Phone
iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot
N/A
RS485
N/A
Alarm
N/A
PIR Sensor Range
N/A
General
Power Supply
DC12V
Power Consumption
< 4.5W
Working Environment
-30°C~+50°C, Less than 95% RH
Ingress Protection
IP66
Vandal Resistance
IK10
Dimensions
Φ110mm×81mm
Weight
0.39kg
