Model | DH-IPC-C10 | |
Camera | ||
Image Sensor | 1/4” 1Megapixel CMOS | |
Effective Pixels | 1280(H)x720(V) | |
Scanning System | Progressive | |
Electronic Shutter Speed | Auto/Manual, 1/3(4)~1/10000 | |
Min. Illumination | 0.01lux/F2.0(color),0lux/F2.0(IR on) | |
S/N Ratio | More than 50dB | |
Video Output | N/A | |
Camera Features | ||
Max. LEDs Length | 5m | |
Day/Night | Auto(ICR) / Color / B/W | |
Backlight Compensation | BLC / HLC / DWDR | |
White Balance | Auto/Manual | |
Gain Control | Auto/Manual | |
Noise Reduction | 3D | |
Lens | ||
Focal Length | 3.3mm | |
Max Aperture | F2.0 | |
Focus Control | Manual | |
Angle of View | 56.7° | |
Lens Type | Fixed Lens | |
Mount Type | Board-in Type | |
Video | ||
Compression | H.264 | |
Resolution | 720P(1280x720)/D1/CIF | |
Frame Rate | Main Stream | 720P(1~25/30fps) |
Bit Rate | H.264: 8Kbps~2Mbps | |
Audio | ||
Compression | AAC | |
Interface | Built-in Mic/Speaker | |
Network | ||
Ethernet | NA | |
Wi-Fi | Wi-Fi(IEEE802.11b/g/n) 30m(open field) |
Protocol | IPv4/IPv6, HTTP, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS,FTP, QoS, | |
Compatibility | ONVIF CGI | |
Max. User Access | 10 users | |
Smart Phone | iPhone, iPad, Android, Windows Phone | |
Auxiliary Interface | ||
Memory Slot | Micro SD, up to 64GB | |
RS485 | N/A | |
Alarm | N/A | |
PIR Sensor Range | N/A | |
USB | Micro USB | |
General | ||
Power Supply | DC 5V | |
Power Consumption | <3W | |
Working Environment | -20°C~+45°C, Less than 95%RH | |
Ingress Protection | N/A | |
Vandal Resistance | N/A | |
Dimensions(W×D×H) | Φ65mmx85mmx 20mm | |
Weight | 75g |
