IP камера Dahua DH-IPC-HFW2200RP-VF уличная мини 2.0Мп, объектив 2.8-12мм, ИК до 30 метров, PoE
Dahua
EndOfSale
Артикул:DH-IPC-HFW2200RP-VF
Код товара: 17290
Dahua
Снят с продажи
Model
DH-IPC-HFW2200R-VF
Camera
Image Sensor
1/2.8” 2Megapixel progressive scan CMOS
Effective Pixels
1920(H)x1080(V)
Scanning System
Progressive
Electronic Shutter Speed
Auto/Manual, 1/3(4)~1/10000s
Min. Illumination
0. 01Lux/F1.4 (Color), 0Lux/F1.4(IR on)
S/N Ratio
More than 50dB
Video Output
N/A
Camera Features
Max. IR LEDs Length
30m
Day/Night
Auto(ICR)/Color/B/W
Backlight Compensation
BLC / HLC / DWDR
White Balance
Auto/Manual
Gain Control
Auto/Manual
Noise Reduction
3D
Privacy Masking
Up to 4 areas
Lens
Focal Length
2.7mm~12mm
Max Aperture
F1.4
Focus Control
Manual
Angle of View
H: 98°~ 30°
Lens Type
Manual/ Fixed Iris
Mount Type
Board-in Type
Video
Compression
H.264/ H.264H/ MJPEG
Resolution
1080P(1920x1080)/1.3M(1280×960)/720P(1280×720)/D1(704×576/704×480)/CIF(352×288/352×240)
Frame Rate
Main Stream
1080P/960P/720P(1 ~ 25/30fps)
Sub Stream
D1/CIF(1 ~ 25/30fps)
Bit Rate
H.264H: 40K ~ 8192Kbps; MJPEG: 40K~16384Kbps
Audio
Compression
N/A
Interface
N/A
Network
Ethernet
RJ-45 (10/100Base-T)
Wi-Fi
N/A
Protocol
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour
Compatibility
ONVIF, CGI, PSIA
Max. User Access
20 users
Smart Phone
iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot
N/A
RS485
N/A
Alarm
N/A
PIR Sensor Range
N/A
General
Power Supply
DC12V/PoE (802.3af)
Power Consumption
< 4.5W
Working Environment
-30°C~+60°C, Less than 95% RH
Ingress Protection
IP66
Vandal Resistance
N/A
Dimensions
72mm×80mm×212.8mm
Weight
0.65kg
