IP камера Dahua DH-IPC-HFW4300EP-0360B уличная мини 3Мп, объектив 3.6мм,PoE.
Dahua
EndOfSale
Артикул:DH-IPC-HFW4300EP-0360B
Код товара: 16850
Dahua
Уличная IP камера 3Мп, Объектив 3.6мм, PoE, ИК подсветка до 30 метров
Снят с продажи
IP камера Dahua онлайн
Model
DH-IPC-HFW4300E
Camera
Image Sensor
1/3” 3Megapixel progressive scan CMOS
Effective Pixels
2048(H)x1536(V)
Scanning System
Progressive
Electronic Shutter Speed
Auto/Manual, 1/3(4)~1/10000s
Min. Illumination
0.01Lux/F1.6 (Color),0Lux/F1.6(IR on)
S/N Ratio
More than 50dB
Video Output
N/A
Camera Features
Max. IR LEDs Length
30m
Day/Night
Auto(ICR)/Color/B/W
Backlight Compensation
BLC / HLC / DWDR
White Balance
Auto/Manual
Gain Control
Auto/Manual
Noise Reduction
3D
Privacy Masking
Up to 4 areas
Lens
Focal Length
3.6mm (6mm,8mm optional)
Max Aperture
F1.8(F1.6/F1.6)
Focus Control
Manual
Angle of View
H:72.5°(44°/33.2°)
Lens Type
Fixed lens
Mount Type
Board-in Type
Video
Compression
H.264/ MJPEG
Resolution
3M(2048×1536)/1080P(1920×1080) / 720P(1280×720) /
D1(704×576/704×480) / CIF(352×288/352×240)
Frame Rate
Main Stream
3M(1~20fps)/1080P/720P(1 ~ 25/30fps)
Sub Stream
D1/CIF(1 ~ 25/30fps)
Bit Rate
H.264: 32K ~ 8192Kbps
Audio
Compression
N/A
Interface
N/A
Network
Ethernet
RJ-45 (10/100Base-T)
Wi-Fi
N/A
Protocol
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour
Compatibility
ONVIF,PSIA,CGI
Max. User Access
20users
Smart Phone
iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot
N/A
RS485
N/A
Alarm
N/A
PIR Sensor Range
N/A
General
Power Supply
DC12V, PoE (802.3af)
Power Consumption
Max 5.5W
Working Environment
-40°C~+60°C, Less than 95% RH
Ingress Protection
IP66
Vandal Resistance
N/A
Dimensions
168.1mm×66mm×58.4mm
Weight
0.5kg
