Управляющий модуль JetCore для Foundry BigIron. 8-портов 1000Base-X (SFP), поддержка S-Flow.
System Parameters Default Maximum Current
ip-arp 8000 64000 8000
ip-static-arp 2048 4096 2048
atalk-route 1024 3072 1024
atalk-zone-port 64 255 64
atalk-zone-sys 768 2048 768
multicast-route 64 8192 64
dvmrp-route 2048 128000 2048
multicast-flow 1024 8192 1024
dvmrp-mcache 512 4096 512
pim-mcache 1024 16384 1024
igmp-max-group-addr 20480 81920 20480
ip-cache 140000 400000 140000
ip-filter-port 512 4096 512
ip-filter-sys 1024 16384 1024
ipx-forward-filter 256 1024 256
ipx-rip-entry 3072 32768 3072
ipx-rip-filter 256 1024 256
ipx-sap-entry 6144 32768 6144
ipx-sap-filter 256 1024 256
l3-vlan 32 4095 32
ip-qos-session 2048 64000 2048
l4-real-server 1024 2048 1024
l4-virtual-server 512 1024 512
l4-server-port 2048 4096 2048
mac 8000 64000 8000
ip-route 140000 400000 140000
ip-static-route 512 4096 512
vlan 32 4095 4095
spanning-tree 32 128 32
mac-filter-port 32 1024 32
mac-filter-sys 64 2048 64
ip-subnet-port 24 128 24
session-limit 262144 1000000 262144
view 10 65535 10
virtual-interface 255 4095 255
vpls-mac 8192 524288 8192
vpls-session 8192 262144 8192
vpls-num 2048 16384 2048
msdp-sa-cache 4096 8192 4096
l2-acl-table-entries 64 256 64
Позволяет подсчитывать трафик по S-Flow
Пример команды:
@hp1(config-if-e1000-1/6)#sh sflow
sFlow services are enabled.
sFlow agent IP address: 127.0.0.100
Collector IP 10.10.10.1, UDP 6343
Polling interval is 20 seconds.
Configured default sampling rate: 1 per 2048 packets.
Actual default sampling rate: 1 per 2048 packets.
27 UDP packets exported
117 sFlow samples collected.
sFlow ports: ethe 1/6
Module Sampling Rates
Slot 1 configured rate=2048, actual rate=2048
Slot 2 configured rate=0, actual rate=0
Port Sampling Rates
Port=1/6, configured rate=2048, actual rate=2048, Subsampling factor=1
Производитель: Foundry
