IP камера Dahua DH-IPC-HFW1000SP-W-0360B уличная мини 1.0Мп, объектив 3.6мм,wi-fi
Dahua
EndOfSale
Артикул:DH-IPC-HFW1000SP-W-0360B
Код товара: 18469
Dahua
Уличная IP камера 1Мп, объектив 3.6мм, Wi-Fi, без PoE, ИК подсветка
Снят с продажи
Model
DH-IPC-HFW1000S-W
Camera
Image Sensor
1/4” 1Megapixel progressive scan CMOS
Effective Pixels
1280(H)x720(V)
Scanning System
Progressive
Electronic Shutter Speed
Auto/Manual 1/3(4)~1/10000
Min. Illumination
Color: 0. 01Lux/F1.8 ; 0Lux (IR on)
S/N Ratio
More than 50dB
Video Output
N/A
Camera Features
Max. IR LEDs Length
30m
Day/Night
Auto(ICR) / Color / B/W
Backlight Compensation
BLC /HLC /DWDR
White Balance
Auto/Manual
Gain Control
Auto/Manual
Noise Reduction
3D
Privacy Masking
Up to 4 areas
Lens
Focal Length
3.6mm (6mm optional)
Max Aperture
F1.8(F1.8)
Focus Control
Manual
Angle of View
H: 59°(37°)
Lens Type
Fixed lens
Mount Type
Board-in Type
Video
Compression
H.264B/H.264/MJPEG
Resolution
720P(1280×720)/D1(704×576/704×480) /CIF(352×288/352×240)
Frame Rate
Main Stream
720P(1 ~ 25/30fps)
Sub Stream
D1/CIF(1 ~ 25/30fps)
Bit Rate
H.264: 448K ~ 8192Kbps
Audio
Compression
N/A
Interface
N/A
Network
Ethernet
RJ-45 (10/100Base-T)
Wi-Fi
Wi-Fi(IEEE802.11b/g/n)
Wi-Fi Range
50m(open field)
Protocol
IPv4/IPv6, HTTP, HTTPS, TCP/IP, UDP, UPnP, ICMP, IGMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS
Compatibility
ONVIF, CGI
Max. User Access
20 users
Smart Phone
iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot
N/A
RS485
N/A
Alarm
N/A
PIR Sensor Range
N/A
General
Power Supply
DC12V
Power Consumption
< 6.5W
Working Environment
-30°C~+50°C, Less than 95%RH
Ingress Protection
IP66
Vandal Resistance
N/A
Dimensions
Φ70mm×66mm×155mm
Weight
0.42Kg
