Model | DH-SD59220T-HN | DH-SD59230T-HN | |||
Camera | |||||
Image Sensor | 1/2.8” CMOS | ||||
Effective Pixels | 1944(H) x 1092(V), 2Megapixels | ||||
Scanning System | Progressive | ||||
Electronic Shutter Speed | 1/3 ~ 1/30,000s | ||||
Min. Illumination | Color: 0.05Lux@F1.4; B/W: 0.005Lux@F1.4 |
Color: 0.05Lux@F1.6; B/W: 0.005Lux@F1.6 |
S/N Ratio | More than 55dB | ||||
Camera Features | |||||
Day/Night | Auto(ICR) / Color / B/W | ||||
Backlight Compensation | BLC / HLC / DWDR (Digital WDR) | ||||
White Balance | Auto, ATW, Indoor, Outdoor, Manual | ||||
Gain Control | Auto / Manual | ||||
Noise Reduction | Ultra DNR (2D/3D) | ||||
Privacy Masking | Up to 24 areas | ||||
Digital Zoom | 16x | ||||
Lens | |||||
Focal Length | 4.7mm ~ 94.0mm | 4.5mm~135mm | |||
(20x Optical zoom) | (30x Optical zoom) | ||||
Max Aperture | F1.4 ~ F2.6 | F1.6~ F4.4 | |||
Focus Control | Auto / Manual | ||||
Angle of View | H: 54.1° ~ 3.2° | H: 67.8° ~ 2.77° | |||
Close Focus Distance | 100mm~ 1000mm | ||||
PTZ | |||||
Pan/Tilt Range | Pan: 0° ~ 360° endless; Tilt: -15° ~ 90°, auto flip 180° | ||||
Manual Control Speed | Pan: 0.1° ~300° /s; Tilt: 0.1° ~200° /s | ||||
Preset Speed | Pan: 400° /s; Tilt: 300° /s | ||||
Preset | 300 | ||||
PTZ Mode | 5 Pattern, 8 Tour, Auto Pan, Auto Scan | ||||
Speed Setup | Human-oriented focal length/ speed adaptation | ||||
Power up Action | Auto restore to previous PTZ and lens status after power failure | ||||
Idle Motion | Activate Preset/ Pan/ Scan/ Tour/ Pattern if there is no command in the specified period | ||||
IR Distance | 80m (DC12V) | ||||
100m (AC24V) | |||||
Video | |||||
Compression | H.264 / MJPEG | ||||
Resolution | 1080P(1920×1080)/ 720P(1280×720) / D1(704×576/ 704×480) /CIF | ||||
(352×288/352×240) | |||||
Frame Rate | Main Stream | 1080P/ D1 (1 ~ 25/30fps), 720P(1~50/60fps) | |||
Sub Stream 1 | D1/CIF(1 ~ 25/30fps) | ||||
Sub Stream 2 | 720P/ D1/ CIF (1 ~ 25/30fps) | ||||
Bit Rate | H.264: 448K ~ 8192Kbps, MJPEG: 5120K ~ 10240Kbps | ||||
Audio | |||||
Compression | G.711a / G.711Mu(32kbps)/ PCM(128kbps) | ||||
Interface | 1/1 channel In/Out | ||||
Intelligent Function | |||||
IVS | Tripwire, Intrusion, Abandoned Object Detection, Missing Object Detection | ||||
Face Detection | Support | ||||
Network | |||||
Ethernet | RJ-45 (10/100Base-T) | ||||
Protocol | IPv4/ IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour, 802.1x | ||||
Compatibility | ONVIF PSIA CGI | ||||
Max. User Access | 20 users | ||||
Smart Phone | iPhone, iPad, Android, Windows Phone | ||||
Auxiliary Interface | |||||
Memory Slot | Micro SD, Max 128GB | ||||
Alarm | 2/1 channel In/Out | ||||
General | |||||
Power Supply | AC24V/ DC12V, POE plus(802.3at) | ||||
Power Consumption | DC12V: 13W, 20W (IR on) | ||||
AC24V: 13W, 23W (IR on) | |||||
Working Environment | DC12V: -30ºC ~ 60ºC / Less than 90% RH | ||||
AC24V: -40ºC ~ 70ºC / Less than 90% RH | |||||
Ingress Protection | IP66 | ||||
Dimensions | Φ186.0(mm) x 309(mm) | ||||
Weight | 3.5kg |
