Model |
DH-IPC-HDPW4100F-WPT |
Camera |
Image Sensor |
1/3” 1.3Megapixel progressive scan CMOS |
Effective Pixels |
1280(H)x960(V) |
Scanning System |
Progressive |
Electronic Shutter Speed |
Auto/Manual 1/3(4)~1/100000 |
Min. Illumination |
0.01Lux/F1.2(color) |
S/N Ratio |
More than 50db |
Video Output |
N/A |
Camera Features |
Max. IR LEDs Length |
15m |
Day/Night |
Auto(ICR)/Color/B/W |
Backlight Compensation |
Off/BLC/HLC/DWDR |
White Balance |
Auto/Manual |
Gain Control |
Auto/Manual |
Noise Reduction |
3D |
Privacy Masking |
Up to 4 areas |
Digital Zoom |
3x |
Lens |
Focal Length |
3.6mm |
Max Aperture |
F1.2 |
Focus Control |
Manual |
Angle of View |
H:70° |
Lens Type |
Fixed lens |
Mount Type |
Board-in Type |
PT |
Pan/ Tilt Range |
Pan: 0°~±180°; Tilt: 0°~90° |
Preset Speed |
100°/s |
Preset |
25 |
Video |
Compression |
H.264/H.264H/ MJPEG |
Resolution |
1.3M(1280x960)/720P(1280×720) / |
Frame Rate |
Main Stream |
1.3M/720P(1 ~ 25/30fps) |
Sub Stream |
D1/CIF(1 ~ 25/30fps) |
Bit Rate |
H.264: 32K ~ 8192Kbps |
Audio |
Compression |
G.711a/G.711u/PCM |
Interface |
Bulit-in Mic |
Network |
Ethernet |
RJ-45 (10/100Base-T) |
Wi-Fi |
Wi-Fi(IEEE802.11b/g/n) |
Protocol |
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour |
Compatibility |
ONVIF PSIA CGI |
Max. User Access |
20 users |
Smart Phone |
iPhone, iPad, Android, Windows Phone |
Auxiliary Interface |
Memory Slot |
N/A |
RS485 |
N/A |
Alarm |
N/A |
PIR Sensor Range |
N/A |
General |
Power Supply |
DC12V, PoE |
Power Consumption |
<5W |
Working Environment |
-30℃~+50℃, Less than 95% RH |
Ingress Protection |
N/A |
Vandal Resistance |
N/A |
Dimensions |
Φ130mm×58.4mm |
Weight |
0.25kg |
