OMNY 500 PRO DH-IPC-HFW4421EP-0360B
Model |
DH-IPC-HFW4421E |
Camera |
Image Sensor |
1/3” 4Megapixel progressive scan CMOS |
Effective Pixels |
2688(H)x1520(V) |
Scanning System |
Progressive |
Electronic Shutter Speed |
Auto/Manual, 1/3(4)~1/10000s |
Min. Illumination |
0.01Lux/F2.0 (Color), 0Lux/F2.0(IR on) |
S/N Ratio |
More than 50dB |
Video Output |
N/A |
Camera Features |
Max. IR LEDs Length |
40m |
Day/Night |
Auto(ICR)/Color/B/W |
Backlight Compensation |
BLC / HLC / WDR(120dB) |
White Balance |
Auto/Manual |
Gain Control |
Auto/Manual |
Noise Reduction |
3D |
Privacy Masking |
Up to 4 areas |
Lens |
Focal Length |
3.6mm (6mm optional) |
Max Aperture |
F2.1(F2.0) |
Focus Control |
Manual |
Angle of View |
H:84°(56°) |
Lens Type |
Fixed lens |
Mount Type |
Board-in Type |
Video |
Compression |
H.264/H.264H/H.264B/MJPEG |
Resolution |
4M(2560×1440)/3M(2304×1296)/1080P(1920×1080)720P(1280×720) /D1(704×576/704×480) / CIF(352×288/352×240) |
Frame Rate |
Main Stream |
4M(1~20fps)/3M(1~25/30fps) |
Sub Stream |
D1/CIF(1~25/30fps) |
Third Stream |
720P(1-5/8fps)(WDR on) |
Bit Rate |
H.264: 32Kbps~10Mbps |
Corridor Mode |
Support |
Audio |
Compression |
N/A |
Interface |
N/A |
Smart Function |
Smart detection |
Tripwire |
Intrusion |
Scene change |
Face detect |
Ethernet |
RJ-45 (10/100Base-T) |
Network |
Wi-Fi |
N/A |
Protocol |
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour |
Compatibility |
ONVIF, PSIA, CGI |
Max. User Access |
20 users |
Smart Phone |
iPhone, iPad, Android, Windows Phone |
Auxiliary Interface |
Memory Slot |
N/A |
RS485 |
N/A |
Alarm |
N/A |
PIR Sensor Range |
N/A |
General |
Power Supply |
DC12V, PoE (802.3af) |
Power Consumption |
< 6W |
Working Environment |
-40°C~+60°C, Less than 95% RH |
Ingress Protection |
IP67 |
Vandal Resistance |
N/A |
Dimensions |
70mm×70mm×180mm |
Weight |
0.4kg(0.528kg with packaging) |
Конец формы
