Online Трансляция
Model | DH-HAC-HDW1200MP | DH-HAC-HDW1200MN |
Camera | ||
Image Sensor | 1/2.7" 2Megapixel CMOS | |
Effective Pixels | 1930(H)×1088(V) | |
Electronic Shutter | 1/50s~1/100,000s | 1/60s~1/100,000s |
Video Frame Rate | 25fps@1080P | 30fps@1080P |
Synchronization | Internal | |
Min. Illumination | 0.01Lux@F1.2(AGC ON), 0Lux IR on | |
Video Output | 1-channel BNC HDCVI high definition video output | |
Camera Features | ||
Max. IR LEDs Length | 30m, Smart IR | |
Day/Night | Auto(ICR) / Color / B/W | |
Noise Reduction | 2D | |
Lens | ||
Focal Length | 3.6mm (6mm optional) | |
Angle of View | H: 89.9º(59.4º) | |
Mount Type | M12 | |
General | ||
Power Supply | DC12V±20% | |
Power Consumption | Max 2.5W | |
Working Environment | -30°C~+60°C / Less than 95%RH (no condensation) | |
Transmission Distance | Over 500m via 75-3 coaxial cable | |
Ingress Protection | IP67 | |
Dimensions | Φ93.4mm×79.7mm | |
Weight | 0.35kg | |
Material | Metal |
