Model |
DH-IPC-HFW2200R-VF |
Camera |
Image Sensor |
1/2.8” 2Megapixel progressive scan CMOS |
Effective Pixels |
1920(H)x1080(V) |
Scanning System |
Progressive |
Electronic Shutter Speed |
Auto/Manual, 1/3(4)~1/10000s |
Min. Illumination |
0. 01Lux/F1.4 (Color), 0Lux/F1.4(IR on) |
S/N Ratio |
More than 50dB |
Video Output |
N/A |
Camera Features |
Max. IR LEDs Length |
30m |
Day/Night |
Auto(ICR)/Color/B/W |
Backlight Compensation |
BLC / HLC / DWDR |
White Balance |
Auto/Manual |
Gain Control |
Auto/Manual |
Noise Reduction |
3D |
Privacy Masking |
Up to 4 areas |
Lens |
Focal Length |
2.7mm~12mm |
Max Aperture |
F1.4 |
Focus Control |
Manual |
Angle of View |
H: 98°~ 30° |
Lens Type |
Manual/ Fixed Iris |
Mount Type |
Board-in Type |
Video |
Compression |
H.264/ H.264H/ MJPEG |
Resolution |
1080P(1920x1080)/1.3M(1280×960)/720P(1280×720)/D1(704×576/704×480)/CIF(352×288/352×240) |
Frame Rate |
Main Stream |
1080P/960P/720P(1 ~ 25/30fps) |
Sub Stream |
D1/CIF(1 ~ 25/30fps) |
Bit Rate |
H.264H: 40K ~ 8192Kbps; MJPEG: 40K~16384Kbps |
Audio |
Compression |
N/A |
Interface |
N/A |
Network |
Ethernet |
RJ-45 (10/100Base-T) |
Wi-Fi |
N/A |
Protocol |
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour |
Compatibility |
ONVIF, CGI, PSIA |
Max. User Access |
20 users |
Smart Phone |
iPhone, iPad, Android, Windows Phone |
Auxiliary Interface |
Memory Slot |
N/A |
RS485 |
N/A |
Alarm |
N/A |
PIR Sensor Range |
N/A |
General |
Power Supply |
DC12V/PoE (802.3af) |
Power Consumption |
< 4.5W |
Working Environment |
-30°C~+60°C, Less than 95% RH |
Ingress Protection |
IP66 |
Vandal Resistance |
N/A |
Dimensions |
72mm×80mm×212.8mm |
Weight |
0.65kg |
Каталог товаров
Екатеринбург
- Покупателям
- Услуги
- О нас
RUB
