Model | DH-IPC-HFW2200R-VF | |
Camera | ||
Image Sensor | 1/2.8” 2Megapixel progressive scan CMOS | |
Effective Pixels | 1920(H)x1080(V) | |
Scanning System | Progressive | |
Electronic Shutter Speed | Auto/Manual, 1/3(4)~1/10000s | |
Min. Illumination | 0. 01Lux/F1.4 (Color), 0Lux/F1.4(IR on) | |
S/N Ratio | More than 50dB | |
Video Output | N/A | |
Camera Features | ||
Max. IR LEDs Length | 30m | |
Day/Night | Auto(ICR)/Color/B/W | |
Backlight Compensation | BLC / HLC / DWDR | |
White Balance | Auto/Manual | |
Gain Control | Auto/Manual | |
Noise Reduction | 3D | |
Privacy Masking | Up to 4 areas | |
Lens | ||
Focal Length | 2.7mm~12mm | |
Max Aperture | F1.4 | |
Focus Control | Manual | |
Angle of View | H: 98°~ 30° | |
Lens Type | Manual/ Fixed Iris | |
Mount Type | Board-in Type | |
Video | ||
Compression | H.264/ H.264H/ MJPEG | |
Resolution | 1080P(1920x1080)/1.3M(1280×960)/720P(1280×720)/D1(704×576/704×480)/CIF(352×288/352×240) | |
Frame Rate | Main Stream | 1080P/960P/720P(1 ~ 25/30fps) |
Sub Stream | D1/CIF(1 ~ 25/30fps) | |
Bit Rate | H.264H: 40K ~ 8192Kbps; MJPEG: 40K~16384Kbps | |
Audio | ||
Compression | N/A | |
Interface | N/A | |
Network | ||
Ethernet | RJ-45 (10/100Base-T) | |
Wi-Fi | N/A | |
Protocol | IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour | |
Compatibility | ONVIF, CGI, PSIA | |
Max. User Access | 20 users | |
Smart Phone | iPhone, iPad, Android, Windows Phone | |
Auxiliary Interface | ||
Memory Slot | N/A | |
RS485 | N/A | |
Alarm | N/A | |
PIR Sensor Range | N/A | |
General | ||
Power Supply | DC12V/PoE (802.3af) | |
Power Consumption |
Working Environment | -30°C~+60°C, Less than 95% RH | |
Ingress Protection | IP66 | |
Vandal Resistance | N/A | |
Dimensions | 72mm×80mm×212.8mm | |
Weight | 0.65kg | |
Уважаемые покупатели.
