IP камера Dahua DH-IPC-HDW1320SP-0280B купольная мини 3Мп, объектив 2.8мм, PoE.
Dahua
EndOfSale
Артикул:DH-IPC-HDW1320SP-0280B
Код товара: 20154
Dahua
Купольная IP видеокамера 3MP; 1/3" 3MP CMOS; фикс. объектив: 2,8мм; сжатие: H.264/MJPEG; разрешение и скорость трансляции видео: 3MP (1~20к/с), 1080P/720P(1~25к/c); чувствительность: 0.045лк/F2.1(цвет),0лк@F2.1(ИК вкл); Дальность ИК:20м; DWDR,3DNR,ONVIF
Снят с продажи
Model DH-IPC-HDW1320SP-0280B
Camera
Image Sensor 1/3” 3Megapixel progressive scan CMOS
Effective Pixels 2048(H) ´ 1536(V)
Scanning System Progressive
Electronic Shutter Speed Auto/Manual, 1/3s~1/30000s
Min. Illumination 0. 045Lux/F2.1(Color), 0Lux/F2.1(IR on)
S/N Ratio More than 50dB
Video Output N/A
Camera Features
Max. IR LEDs Length 30m
Day/Night Auto(ICR)/Color/B/W
Backlight Compensation BLC / HLC / DWDR
White Balance Auto/Manual
Gain Control Auto/Manual
Noise Reduction 3D
Privacy Masking Up to 4 areas
Lens
Focal Length 2.8mm
Max Aperture F2.1(F2.0, F1.9)
Focus Control Manual
Angle of View H: 92°
Lens Type Fixed lens
Mount Type Board-in Type
Video
Compression H.264/ H.264H/ H.264B/ MJPEG
Resolution 3M(2048×1536)/3M(2304×1296)/1080P(1920×1080)/720P(1280×720)/ D1(704×576/704×480) /CIF(352×288/352×240)
Frame Rate Main Stream 3M(1 ~ 20fps)/1080P(1 ~ 25/30fps)
Sub Stream D1(1 ~ 25/30fps)
Bit Rate H.264: 4kbps~8192bps
Corridor Mode Support
Audio
Compression N/A
Interface N/A
Network
Ethernet RJ-45 (10/100Base-T)
Wi-Fi N/A
Protocol IPv4/IPv6, HTTP, HTTPS, TCP/IP, UDP, UPnP, ICMP, IGMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS
Compatibility ONVIF, CGI
Max. User Access 20 users
Smart Phone iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot N/A
RS485 N/A
Alarm N/A
PIR Sensor Range N/A
General
Power Supply DC12V, PoE (802.3af)
Power Consumption <3.7W(IR on)
Working Environment -30°C~+60°C, Less than 95% RH
Ingress Protection IP67
Vandal Resistance N/A
Dimensions Φ108mm×84mm
Weight 0.25Kg(with package 0.38Kg)
