IP камера Dahua DH-IPC-C10P мини корпусная 1Мп, объектив 3.3мм, WiFi, 5В
Dahua
EndOfSale
Артикул:DH-IPC-C10P
Код товара: 17294
Dahua
Снята с производства
Снят с продажи
Новое поколение мини камер для дома и офиса Dahua
Model DH-IPC-C10
Camera
Image Sensor 1/4” 1Megapixel CMOS
Effective Pixels 1280(H)x720(V)
Scanning System Progressive
Electronic Shutter Speed Auto/Manual, 1/3(4)~1/10000
Min. Illumination 0.01lux/F2.0(color),0lux/F2.0(IR on)
S/N Ratio More than 50dB
Video Output N/A
Camera Features
Max. LEDs Length 5m
Day/Night Auto(ICR) / Color / B/W
Backlight Compensation BLC / HLC / DWDR
White Balance Auto/Manual
Gain Control Auto/Manual
Noise Reduction 3D
Lens
Focal Length 3.3mm
Max Aperture F2.0
Focus Control Manual
Angle of View 56.7°
Lens Type Fixed Lens
Mount Type Board-in Type
Video
Compression H.264
Resolution 720P(1280x720)/D1/CIF
Frame Rate Main Stream 720P(1~25/30fps)
Bit Rate H.264: 8Kbps~2Mbps
Audio
Compression AAC
Interface Built-in Mic/Speaker
Network
Ethernet NA
Wi-Fi Wi-Fi(IEEE802.11b/g/n)
30m(open field)
Protocol IPv4/IPv6, HTTP, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS,FTP, QoS,
Compatibility ONVIF CGI
Max. User Access 10 users
Smart Phone iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot Micro SD, up to 64GB
RS485 N/A
Alarm N/A
PIR Sensor Range N/A
USB Micro USB
General
Power Supply DC 5V
Power Consumption <3W
Working Environment -20°C~+45°C, Less than 95%RH
Ingress Protection N/A
Vandal Resistance N/A
Dimensions(W×D×H) Φ65mmx85mmx 20mm
Weight 75g
