IP камера Dahua DH-IPC-HFW1120RMP-0360B уличная мини 1.3Мп, объектив 3.6мм, ИК подсветка до 20 метров, PoE.
Dahua
EndOfSale
Артикул:DH-IPC-HFW1120RMP-0360B
Код товара: 17293
Dahua
Снят с продажи
Model
DH-IPC-HFW1120RM
Camera
Image Sensor
1/3” 1.3Megapixel progressive scan CMOS
Effective Pixels
1280(H) ´ 960(V)
Scanning System
Progressive
Electronic Shutter Speed
Auto/Manual, 1s~1/100000s
Min. Illumination
0. 01Lux/F2.1(Color), 0Lux/F2.1(IR on)
S/N Ratio
More than 50dB
Video Output
N/A
Camera Features
Max. IR LEDs Length
20m
Day/Night
Auto(ICR)/Color/B/W
Backlight Compensation
BLC / HLC / DWDR
White Balance
Auto/Manual
Gain Control
Auto/Manual
Noise Reduction
3D
Privacy Masking
Up to 4 areas
Lens
Focal Length
3.6mm(6mm optional)
Max Aperture
F2.1(F1.9)
Focus Control
Manual
Angle of View
H: 71°(47°)
Lens Type
Fixed lens
Mount Type
Board-in Type
Video
Compression
H.264/ H.264H/ H.264B/ MJPEG
Resolution
1.3M(1280x960)/720P(1280×720)/ D1(704×576/704×480) /
CIF(352×288/352×240)
Frame Rate
Main Stream
1.3M/720P(1 ~ 25/30fps)
Sub Stream
D1(1 ~ 25/30fps)
Bit Rate
H.264: 4Kbps8192Kbps
Corridor Mode
Support
Audio
Compression
N/A
Interface
N/A
Network
Ethernet
RJ-45 (10/100Base-T)
Wi-Fi
N/A
Protocol
IPv4/IPv6, HTTP, HTTPS, SSL, TCP/IP, UDP, UPnP, ICMP, IGMP, SNMP, RTSP, RTP, SMTP, NTP, DHCP, DNS, PPPOE, DDNS, FTP, IP Filter, QoS, Bonjour
Compatibility
ONVIF, CGI
Max. User Access
20 users
Smart Phone
iPhone, iPad, Android, Windows Phone
Auxiliary Interface
Memory Slot
N/A
RS485
N/A
Alarm
N/A
PIR Sensor Range
N/A
General
Power Supply
DC12V, PoE (802.3af)
Power Consumption
<3.8W
Working Environment
-30°C~+60°C, Less than 95% RH
Ingress Protection
IP67
Vandal Resistance
N/A
Dimensions
154mm×60mm×59mm
Weight
0.29Kg(with package 0.42Kg)
